When it gets cold .... my door handles freeze up. I can open a door, but they freeze open. So what happens is, that when you close the door, the door catch doesn't in fact catch, and won't stay closed. The internal mechanism must be freezing, such that the door opens, but the catch mechanism doesn't return.
Sometimes, I have to hold the door closed from the inside, then operate the door locks to "hold" the door closed. Good job my car is a 3 door model, as sometimes I've had to use the boot to get out !
After taking it to a Fiat dealer, they squirted de-icer or whatever into the door to sort it. But its only a short term solution.
Does anyone know a long term fix ? Is it worth stripping the inside of a door out, and taking a look ? I've not been able to find a diagram of the door, to find what is in fact sticking internally. The handle itself works fine, its whatever it pulls, is not returning correctly. Perhaps a stronger return spring is required ?
