General  Mud flaps - easy enough to fit?
You mean flaps Yazza..as in big black chunks of black rubber ..:p all bracket normally come supplied..(y)
they weere off that msc trading guy on ebay supposed to be all genuine so im hoping they will have the fitting bits supplied...noticed someone recommended getting them off msc in another thread.
mmm flapps.
flappy :)
Yeah they come with the bits but you might be wise to bolt them on as well as my rear ones lasted about 3 weeks but the fronts are still with me and the car.
You just need a drill to make a small hole on the bottom rear wing underside (only plastic) plus an allan key and that's it.
Mine are still on but you need to watch reversing over high kerbs.
you dont need to drill
fiat ones come supplied with 6 u shaped brackets that let a bolt come in from one side (like a clamp) to clamp it in position.
its a case of jack up, wheel off (makes it easier) position, and then bolt in place, put wheel back on, put car back on floor.
be careful not to screw them in too hard or else it will damage the bumper where the guard covers it up, meaning it will look daft if you ever take them off
Well i will be bolting the next ones i buy on the blasted car as im not wasting another 26 odd quid on a set, And yes just one bolt or something each side would be enough to stop you losing them like i have.
Those u bolts are ok but they just dont stop the flap being pulled off if you have to dive into a overgrown hedge/bank. But then if you live in a town or city yeah no problem.
And you certainly dont need to jack the car up or even take the wheel off and i managed to get them on a treat, just the stupid u brackets didnt work. Hence a small bolt!!!!!!!!
Oh and yes MSC trading are great people to deal with.
Did you miss the 2 black screws from out of the pack then :confused:
Screws in from directly underneath (agreed; it's best to use a jack (y)) and is quite critical for holding the mud flap in exactly the right position - and worth taking some time over to get it just right :)
Mine only came with the 6 'clamps', no other black screws :(
Not drilled, but was tempted to do so. Mind you, fingers crossed they've lasted in the snow and going through a couple of rough-ish tracks without falling off - having now tempted fate they're bound to come off :rolleyes:
yes.
attachment.php
Click here for a reeeeeeeeeeeeally biiiiiiiig photo.
oh bugger
why?
Back of the genuine Fiat front flaps have a contoured recess to butt up to the leading front edge of the sill...
Have on both Stilos added spire clip behind self tapper that goes through inner wheel arch liners, behind the liner so flap is bolted through and not just self tapped into plastic wheel arch liner, for security and also add a couple of self tappers with spire clips to the rears under the back bumper for the same reason. A bit belt & braces but I have not lost a flap yet... :D
so they will fit with skirts?
i'd say no.
however, if you have skirts, i think they prevent the usual damage to paint work on the rear quarter panels on stilos without skirts
on the rears, i used just the fiat fitments and only lost a guard after sinking in mud on a country lane. however, guard retrieved and refitted, never came off or loose in normal conditions
