General  Fiat stilo key fob programming
Just been quoted £205 for a replacement key and remote fob.
the ones without the remote part are much cheaper. If you are tempted to buy a key on e-bay, don't. It probably wont work with your car and you will waste your money when they try to program it and can't. They come in many different series and the correct series has to be ordered for your car.
mayb its worth the 5 pound risk in comparison to the 205 pound fiat charge
I think mine was £140 from the local stealer just for the remote keyfob and then £30 to code it iirc.
Just had a key cut and sent from Italy at £145, programming cost £80. Incuded a bit of diagnostic work as I only had the one key.
Hi!
Did anyone hear about the coding of the key by inserting the "blank" key to the keyhole, turn it to "MAR" and then press the brake paddle by the key code with pause between the digits?
Maybe just a joke, but did anyone try it?
Hi!
It would make life very easy for a car thief if this did work, so I doubt it.
