Thread Tools
Old 17-04-2008   #1
End of an era!
Stilomeister's Avatar
Stilomeister has donated!
Door Latch Problem
Had a problem with my inner door handle not working yesterday (Great just as I enter MOT station!) After stripping out the door, I found that the cable had come out on the latch end. I re-fitted it and gave everything a good spray with WD-40 including the outer door handle guide. The mechanism must have stiffened up over time and the resistance eventually made the cable end pop out,as after I had done this everything was much better, so I would advise giving it a good squirt every now and then and you may avoid similar embarassment
Stilomeister is offline Reply With Quote Quote
Thread Tools
(T) Brava Problems - Door Latch & Suspention Arm Roddy Mac Bravo / Brava 2 05-02-2008 19:31
(T) I want to change the latch of the doors ata843 Cinquecento / Seicento 1 09-12-2006 22:01
(T) Help! Rear Window latch problem Stephen Carter Doblo 8 27-10-2006 16:25
(T) Boot latch butler Grande Punto 5 30-09-2006 19:27
(T) Hood latch cable newportz Punto (Mk2/2b) 6 23-12-2004 14:35
