Sorry if this has been posted before... seen faults with them but not the same as this....
when i go into reverse all hell breaks loose.... its real paranoid.... one minute its kicking off.... saying somethings there... then its all ok....
managed to clean all the connectors to the ecu in the boot... both the two outside sensors taken off and cleaned... but it still does it....
it didnt do it this morning on the way to work... worked fine.... same when i left work.. all seemed ok....
then as i got on the drive.... it hasnt a clue..... it did the same outside a mates house too..... its usually after a run.. never before....
only thing i notice is that one of the faces to the sensors are silver...(as in metal... not painted) and all the rest are matt black...
even did a CAN scan to look for faults but it hasnt any....
anyone got any advice....
might have to pick one up ..... to test each one.....
