stiloalex25
- Jun 14, 2007
- 4
- 1
Hi I’m new to the forum and have been having problems with my stilo and hoped you could help.
The problems began over a month ago when the Engine Management Light came on and it bleeped saying ‘engine fault- stop engine’. There seemed to be no problem as the car drove around town with seemingly no problem until I began accelerating down a motorway sliproad when the acceleration just seemed to stop. I later noticed driving along that the revs hit a wall at around 4000rpm and won’t go beyond this.
I called out the RAC who plugged in their diagnostic computer and it came up with three fault codes (I don’t have them) but they were cam sensor, crank sensor and knock sensor. He said the sensors were interlinked and the most common to fail was the cam sensor. This was replaced in the garage (an RAC recommended one, not a fiat dealer) the following day yet the problem was still there at high speed (never noticeable at low revs around town). They then replaced the crank sensor and knock sensor yet the problem persisted. The error code had been deleted and only returns once it has been driven up to the high revs where the problem is. The garage then said it may be the ECU which is faulty. As this is a pricey repair I was keen to get a second opinion from a fiat dealer.
The dealer has had it in for around a week and checked all the connections around the sensors and do not know what the problem is. I believe only the knock sensor fault comes up now although I’m not 100% sure of that. The dealership has also said it could be the ECU but are reluctant to change it out as they are in no way certain, it is just an educated guess.
They say they have looked at spark plugs, oxygen sensors, the exhaust and rechecked the knock sensor and they are all fine and so they are stumped.
I read somewhere on this forum that cars have 2 knock sensors. Is that true? I believe I have only had 1 replaced so could it be my other one?
I would really appreciate it if anyone knows what this fault is as it’s getting more and more frustrating and expensive as time goes buy.
I also get an airbag failure warning flash up intermittently for the last few months. Don’t know if this related or not but thought I’d give you all the info.
The car is an 02 reg Stilo 1.6 Dynamic.
I hope you can help!
