Coming from a fellow 1.6er the mpg your reporting is a little worrying, currently in stop/start commuting im probably returning 32ish, but regular commuting I get around 36!
(Click to enlarge)I've also got a OBD PC interface on its way, will this help me locate the problem?
Ooo Ya!
Ok try this. Sometimes it just needs a good slapping. You're just going to kid your motor that the MAP has died and you've fitted a new one
So disconnect the map sensor- here it is
Start the car- it'll bitch a bit that there's an engine fault ya da ya da
but it will run real fine so take it for a short trip
If you want you could reset trip A and see what av cons it kicks out now
Ok engine off and now reconnect the MAP and MOST IMPORTANTLY clear the fault codes- remember you need the ignition on but engine not started to read and clear codes (See if there's any other fault codes there by the way and make a note if there are)
Anyway, imaginary new MAP installed now(ahem)
Start engine and it should be happy with new MAP sensor. Oh Joy
Off you go and let it relearn what a good MAP should be. Reset your trip B and see what av cons figure you're getting now compared to trip A
What software are you going to use? Gendan is pretty good if you're not sure, you can download it, pay for it (about £25 I think) and it's up and running within the hour. Then you can do live graphs as you drive around to see what's happening from a load of engine sensors as well as read and clear fault codes
View attachment 35168(Click to enlarge)
Top graph shows rpm and 02 sensor output. O2 is swinging nicely between 0.15v and 0.85v like a good little O2 sensor
Bottom graph shows car speed and MAP sensor output. This is a good MAP and you can see the MAP output closely follows the rpm but is slightly ahead
just like it should be- air first then revs
PMSLFingers crossed this will fix it; I’m skint at the moment due to the amount of fuel the car is using!!![]()
i get low 30's on motorway and mid 20's city... average
Mine's on 36.1mpg av consumption at present
More cold starts? More use of headlights/heated screen/fan etc due to colder weather?
Ooo Ya!
