Hi guys,
I’ve had a knocking coming from the front of my 2004 1.6 3 door when going over bumps ever since I bought it about 4 months ago. I’ve changed both drop links and checked everything I can but it’s still not getting any better. The track rod ends are fine with no play at all, and the spring catcher is not rubbing on anything.
This weekend I decided to have one last final look (as well as cleaning my air control valve) as my lowering springs are coming this week.
I still can’t find anything that could be knocking! Though I did tighten up the top suspension strut mount as tight as it would go with a massive bar! This has made a slight improvement but it still knocks when going over bumps.
What could it be? I’m thinking as it got better with tightening up the top mount nut it may be the top bearing/strut mount? Do these knock? I’m thinking I may as well replace these as I’m taking them off when I replace the springs.
Anyone have the parts numbers of the parts I should be replacing?
The only other thing I can think of is the lower suspension arm bushes? Anyone know if these are prone to fail/knock?
Any advice appreciated, as these is doing my head in! If it’s not fixed by the time I’ve put my new springs on, I think I’ll change the suspension for some scaffolding bars!
Matt :worship:
Matt :worship:
