FIAT Auto Specialist Team
Old 20-09-2017   #1
Sweden
What does this valve do?
I want to replace the thermostat housing before i refit the head but cannot find one with a fitting for the pipe to this valve,what does it do? Can be deleted? Is it only for the Swedish market as i have a spare Uno 1.3 motor which has the same valve on it.
stevieg32 is offline Reply With Quote Quote
Old 21-09-2017   #2
s130 has donated!
Re: What does this valve do?
I've no come across this configuration before but I have an idea.
You do not say where that steel pipe with bulbous end (diaphragm/one way valve/?) connect to. Also what is behind the union on the thermostat body?
Given Sweden, cold weather starting and their traditionally lower emissions regulations back in the 80s then I would think that this is part of a regulation mechanism to assist engine and carb warm up.
Does the remote end of the pipe connect to a vacuum (car / manifold) union or another water pipe?
s130 is offline Reply With Quote Quote
Old 21-09-2017   #3
Moderator
g8rpi's Avatar
g8rpi has donated!
I think that may be a tapping for throttle body heating water jacket. As S130 says where does the other end go?
You may be able to drill and tap a "standard" housing or get an engineering company to do it for you
Likes Peter Pick-Up liked this post
g8rpi is offline Reply With Quote Quote
Old 21-09-2017   #4
Sweden
Quote Originally Posted by s130 View Post
The diaphragm end goes straight into the air filter,so the water travels along the pipe to the diaphragm/valve but does not recirculate,no idea what it does but it could be to do with cold starting in a Swedish winter.It's only going to be used as a summer car so i think it will be o.k blanked off at the head with new thermostat housing.
Old 21-09-2017   #5
Sounds like the diaphragm may be meant to operate a flap that controls whether the air entering the carb comes from around the exhaust manifold or cold air from elsewhere , depending on engine coolant temperature. The Idea is to prevent carb icing in cold weather.
If that's the case and it's a summer car then blanking it off should be fine.
Likes stevieg32 liked this post
jackwhoo is offline Reply With Quote Quote
85s 1500 valve springs -heavier bmw valve spring as alternative spoonmann Lets Talk FIAT 5 18-10-2011 10:04
(G) Blow Off Valve or a Dump valve on my easytronic GP !!!?? GP Egypt Grande Punto 17 25-12-2009 14:38
bleed valve/adjustable boost control VS FSE Powerboost valve Bushboy Lets Talk FIAT 33 22-02-2006 17:58
(T) Eco-Tek Valve & Powerboost Valve - Are they worth it? MagnaMorbius Bravo / Brava 16 02-02-2006 23:54
Stuck cold start valve or air valve ?????????????? Anglowelsh FIAT Boo Archives 1 21-10-2003 14:30
