I'm not sure. Is it an early 1.6 or later 1.2 (they have different interiors). The 1.6 has seatbelt pre-tensioners which incorporates an explosive charge in the seatbelt mounting, so great care is needed when handling them. There is a special tool which is mounted at the back of the pre-tensioner which you use to disable it before you remove it. I recommend you disable it before disconnecting or connecting the electrics.
