Thread Tools
Old 11-11-2017   #1
Croatia
Losing water with no visible leak
Hello guys,
as title says, my MK1 is losing water with no visible leak, but it's not overheating (checked with scan tool, when temperature goes above 90 celsius fan kicks in and keeping it at that level). Here are some things I did/checked:
- bleeded system several time
- checked every single part for leaks
- no bubbles in expansion tank
- no heating in cabin as of now
- no steam out of exhaust
- both hoses are warm
- when you turn off the car water coming out of expansion tank
- scan tool showing "System MAX Rich" (recently)
- car is running smoothly, no hesitation
Temperature gadget (not sure that's right word) in cabin showing that car is warmer than actually is. Before, fan would kick in just above middle line, now way above, although scan tool is showing that temperate is not that high as gadget says. I believe some air is tricking gadget and that same air could lead to "System MAX Rich" condition?
Thanks in advance,
Greetings from Croatia.
VitaPepe is offline Reply With Quote Quote
Old 11-11-2017   #2
Moderator
Peter Pick-Up has donated!
Russia
Re: Losing water with no visible leak
Have the cooling system presurized at a good workshop.
Thanks VitaPepe thanked for this post
Peter Pick-Up is offline Reply With Quote Quote
Old 11-11-2017   #3
Croatia
Quote Originally Posted by Peter Pick-Up View Post
I like to do things on my own, so I think I could make pressure tester from bicycle pump.
Old 11-11-2017   #4
Moderator
Russia
Old 11-11-2017   #5
Moderator
Russia
Or this, together with your own air compressor:
https://www.ebay.com/itm/Car-Cooling...tYs5ET&vxp=mtr
Old 11-11-2017   #6
Croatia
You need a pump like this:
Yeah, just saw that one on ebay. Though, it's pretty expensive cause it comes in package for more car manufactures. Then I stumbled upon DIY bicycle pump tester which I would connect to that little hose on side of the expansion tank, I don't think it needs to be connected to expansion tank cap or i'm wrong!?
http://prntscr.com/h92bbd
Something like this.
Old 11-11-2017   #7
Croatia
Yeah, we're thinking the same. Thank you for idea.
Old 11-11-2017   #8
Moderator
Russia
Don't put to much pressure on the system though, no more than ~2 bar I suggest.
It should keep pressure for at least 10 minutes or more.
If coolant seeps out visible, you know what to do.
If it looses presure with no visible leaks, I suspect headgasket...
Old 11-11-2017   #9
Croatia
Thank you for advises. Will test it tomorrow and reply with results.
Old 13-11-2017   #10
Ireland
I would suspect head gasket.
digger58 is offline Reply With Quote Quote
Old 16-11-2017   #11
I had a slight leak in my MK1 a few years ago, only sign was a slight mark down the side of the passenger side carpet where the heater matrix is.
I put some K seal in and it stopped the leak.
Now when I flush the cooling system I put a fresh bottle of K seal in " just in case" as it will seal any small leaks as they develop.
Puntonaka is offline Reply With Quote Quote
Old 16-11-2017   #12
Ireland
I replaced my heater matrix in the cabrio, a real b..ch of a job but worth it, they are very cheap as well, Not a fan of any of the quick fix stuff.
Old 17-11-2017   #13
Spain
Cylinder head gasket
rolandbrindley is offline Reply With Quote Quote
Old 20-11-2017   #14
Croatia
Okay. Went to mechanic, actually not mechanic, but parts changer. As soon as I told him I didn't do machine work on cylinder head, he said it's 100% head gasket. Although I was pretty sure it's not, since I checked it for straightness, I gave it a try. He did machine work on it and changed all of the gaskets, radiator cap, some plastics, added antifreeze etc. 150 total work, for... NOTHING!
Next day I saw green spot under the car, it was radiator that was bleeding heavily. Now i'm going to get a new radiator and replace it myself.
Question, will Punto 55 radiator fit on my Punto 75? I have cheap used one from friend of mine, almost new. But from what I saw on internet dimensions are different, just double checking.
Next time I'll listen ScannerDanner:
http://prntscr.com/hcs55d
Old 09-12-2017   #15
bluejohn125 has donated!
Did you make any progress? I imagine a 55 radiator would work in a 75 car if it can be fitted, the size may be smaller?
To me your problem sounds like a leaking heater matrix, this would explain the heater problem inside the cabin. You should notice condensation in the cabin on a cold morning, and there can be a bad smell also from the coolant.
Putting a sealant in the system is an OK solution but not the best, and I would certainly only do it ONCE but certainly not after you have changed / serviced the cylinder head and put nice new coolant in the car.
I don't know the Punto design but I had this problem with my Brava (FIRE) a few years ago, first I sealed the leak then changed the matrix (not an easy job).
bluejohn125 is offline Reply With Quote Quote
Thread Tools
(T) Water leaking only under pressure, no visible leak (fotos) leootzen Punto (Mk2/2b) 5 19-09-2012 12:08
(G) losing water kilt101 Punto (Mk2/2b) 2 21-10-2009 20:21
(G) losing water from ? gazzatop Punto (Mk2/2b) 2 14-11-2007 12:59
(T) losing water bigpigeon2004 Cinquecento / Seicento 14 28-12-2005 22:54
(T) I'm losing water... baz_78 Cinquecento / Seicento 7 21-11-2005 14:29
