Thread Tools
Old 15-03-2014   #1
Ireland
Only cold air
So still having issue with my heater!, so far I have flushed system, check thermostat and bleed it but still only blows cold air!
The car is not over heating at all! I'm at a loss guys any idea or help???
Alextru is offline Reply With Quote Quote
Old 16-03-2014   #2
Trader Rating: 5
fingers99 has donated!
Re: Only cold air
How did you check the stat?
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 16-03-2014   #3
Ireland
Re: Only cold air
Remove it pan of boiling water it opens cold water it closes
Old 16-03-2014   #4
Up to no good somewhere..
maggers's Avatar
maggers has donated!
Re: Only cold air
Is the hot/cold flap working on the heater box?
maggers is offline Reply With Quote Quote
Old 16-03-2014   #5
Ireland
Re: Only cold air
Can hear it Switch over yes
Old 16-03-2014   #6
maggers's Avatar
Re: Only cold air
Are the heater pipes getting warm?
Old 23-03-2014   #7
Netherlands
Re: Only cold air
And How about your temperature sensor?
sxdriver is offline Reply With Quote Quote
Old 23-03-2014   #8
flisko has donated!
Re: Only cold air
touch the pipes behind the engine where the bleed screw is, they should be hot
did u try reving the engine
post 13
flisko is offline Reply With Quote Quote
Old 23-03-2014   #9
Burkina Faso (Upper Volta)
Re: Only cold air
its probably all furred up or full of old goo
if pipes are getting hot in and out it confirms that heater matrix will need replacement
be sure to completely flush out rest of system too though or it will bung up again
radiator leak fixes (snake oils) often block up these matrixes quicker than you can say shazam, this is one reason why i always implore fello fiatforum users not to deploy these products
poor or no antifreeze causes this issue too
Thanks Alextru thanked for this post
s and b is offline Reply With Quote Quote
Thread Tools
(T) no cold air or hot air 00 punto traynor1892 Punto (Mk2/2b) 0 25-11-2009 00:29
(T) No cold air laroc Punto (Mk2/2b) 7 31-07-2008 12:09
(T) Hurray!! Finally Cold Cold air! Geoff Stilo 3 09-06-2007 22:16
(T) overheating with hot air then cold air boothy Punto (Mk2/2b) 6 20-08-2006 07:05
(T) cold air - where to get it from blitzen Cinquecento / Seicento 6 15-11-2003 23:43
