Elxpunto90
Member
- Mar 24, 2013
- 271
- 53
Can anybody help me I am having problems with my Punto elx 90 1.6 8v it has trouble starting up from cold but once started it idles fine and then it reaches temp sothe fan kicks in and out but even before it gets to temp it will rev over 3000 rpm at idle but as soon as I drive it it will start dying after 3000 rpm and try's to konk out then when it has been upto temp for a while when idle it starts to run lumpy and eventually stalls
I had this problem before I changed head gasket , waterpump , oil filter , oil flushed water sytem . New cambelt and tensioner had valve clearances done and new thermostat and oil seals just don't understand what is causing it any ideas please
