Hello,
I have just asked the garage to do a compression test on my 1996 Fiat Punto 55s 1108 as I wanted to check whether there were undetected problems with the head gasket etc before shelling out on other repairs needed (replacing water pump along with replacing timing belt given this has to be removed to get to the water pump anyway and car has done around 87 000 miles).
I was told that for cylinders 1, 3 and 4 their psi is 100 but cylinder 2's is 60. However I'm having trouble finding out what they should be - the Haynes manual tells you how to do a compression test but not what the results should be! Similarly a quick Google isn't bringing anything useful up so I wondered if someone here may know please? He did also say that spark plug 2 needs to be replaced.
The mechanic said that 100 is ok but 60 is a bit low but in his opinion doesn't need replacing now. However I only got the car for £395 a month ago and the repairs will cost around £350 plus the costs for initial quote, so don't want to pay this only for further work needing to be done soon. I wondered if anyone can tell me what is an acceptable psi for this car and what the difference in the results for the cylinders shows?
Would be really grateful if anyone can advise.
Cheers.
Cheers.
