The old warhorse (MK1 N-reg) has recently started to struggle a little when she's first turned over. Currently, she's not failed to start, although it seems to be taking two or three attempts. If she starts on the first attempt, sometimes power will cut out a second or so after. However, once she's up and running, everything is fine. I think it's the battery - sparks were only changed last month, and the problem is worse if you try to start her with the radio or lights on.
I've never undertaken any battery maintenance - is there anything which might help...I've seen some 'Bat-Aid' tablets...anybody any experience or advice?
