david295 Established member Joined Sep 11, 2010 Messages 604 Points 235 Location New Brighton Wirral Jan 23, 2011 #2 milbourne said: as above Click to expand... am certain they dont have relays, i have haynes manual infront of me and i can not see one on wiring diagram
OP OP M milbourne New member Joined Jan 14, 2011 Messages 26 Points 8 Jan 23, 2011 #3 are you able to upload the diagram for me pretty please
david295 Established member Joined Sep 11, 2010 Messages 604 Points 235 Location New Brighton Wirral Jan 23, 2011 #4 milbourne said: are you able to upload the diagram for me pretty please Click to expand... pm me your email address, and i will scan it and email you it
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 Jan 23, 2011 #5 Yes the Horn has a relay I think it is in the Engine bay, If you pop the cover off - it'll show you the location Same for the inside cabin fuse box too edit: - Have you also check the fuse for the horn? If you haven't i'd check that, usually the relay for it wont be too far away Ziggy
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 Jan 23, 2011 #6 david295 said: am certain they dont have relays, i have haynes manual infront of me and i can not see one on wiring diagram Click to expand... Same Thread starter, and you give a different answer lol OP - Here is the thread you started earlier, where david295 has given the answer https://www.fiatforum.com/punto/260410-fuse-relay-number-mk2-punto.html Ziggy
