messiah001
- Jan 16, 2011
- 3
- 1
I have a Punto 60 team 99 reg and it been fine but two days ago when i turned the key I can hear a rapid clicking (this is under a little black cover at rear off engine bay, think it a relay/solenoid) and the key code light goes on and of at the same rate, but nothing else happens (no power to the starter). I can bump the car and drive it (everything works) but cannot start it, so I dont think it a code problem. This isn't a starter motor problem, it certainly the wiring before. Can anyone give me clues as this may be a easy to fix fault that you may have had ( I suspect something like a dodgy connection/earth loose/relay fault/damp connection etc etc), if so a brief description of where the item is. I am getting a manual today.
