Styling springs and shocks
Looks like 35mm drop to me.
You got a better side on photo?
Dampers wise Bilstein OE spec are very good for road use IME
Its quite stiff and speed bumps are a no go tbh
other than that tho it handles well and takes corners at higher speeds without even thinking about it
whats your budget?
coilovers will get you really low, and offer decent handling (not when completely decked). A decent set of FK's will set you back about £500ish
or you can get a decent damper and spring set up, the cost, dependant upon which you go for.
I will just say the same as always - Eibach springs with bilstein OE shocks is excellent for road use.
No harder than standard suspension but transforms the handling.
45-50/35-40mm drop is still very practical on the sportline springs also.
Camber will automatically dial in to 1 degree which is also very good for handling.
Spax/Pi are not as smooth as the eibachs.
£400 will get you the setup I listed.
I think it came in around £360.
Edit : £356.10 from Europerformance
whats your budget?
whats the ride like on coilovers, apparently realy bumpy?
Look if u have money definately go with coilovers... If u buy better ones u will have the ability to set not only height but the hardness of them...
I have coilovers on my punto and i can say only the best for it.
how much did they set u back?
