Hiiii Everybody!
Hiiii Dr Nick!
Joined this forum after picking up a 1994 Punto SX 1.7TD.
It all seems in good order other than a couple of faults
But my main question is about the running temperature.
Even on these hot days it's running around the 1/4 and sometimes under, I've done some long runs on the motorway and been stud in traffic and it still will not raise much further than 1/4.
Is this a problem, I've found limited information on here and else where that it could be a thermostat problem. Does this need fixing ASAP or will the car be ok until I can source a new thermostat?
She still starts fine, runs fine and returns expected MPG.
Any help would be great.
Hiiii Dr Nick!
- Sun Roof is stuck closed, but not leaking (can get a sunroof for £20)
- Heater matrix is only blowing hot or cold air onto window, but not through all the other vents.
- Rear window heater not working (fuse)
- Rear washer squirter not getting water to window.
- Rear light needs bolt, some how one of them is missing!
