Old 21-02-2008   #1
fuel ignition warning light
I had to have a new alternator fitted a few weeks ago and since then I now have the fuel ignition warning light on constantly and I am using more petrol. The mechanic who fitted the alternator has had someone do a diagnostic check but they couldn't get a reading.I am disabled and don't have a lot of money and I believe Auto Electricians are very expensive!!! I am hoping maybe someone has any ideas.
dodgemeg is offline Reply With Quote Quote
Old 22-02-2008   #2
Re: fuel ignition warning light
Follow up.Taken for diagnostic test today and they reckon I need a new ECU.The other thing they told me is that the RAC man that came out to me when I originally broke down should not have put jump leads on to my battery and charged it as this can damage the ECU.Does anyone know if this is correct?
Old 22-02-2008   #3
Forum Moderator
T14086's Avatar
T14086 has donated!
Possible but rare on fiats (happens alot on alfas) dont suppose you know the error codes from the diagnostic?
Thanks dodgemeg thanked for this post
Old 22-02-2008   #4
No,sorry I don't
Old 22-02-2008   #5
Taken to a Auto Electric today to price ECU. They checked and the ECU is fine,showed problem with Pressure Sensor but couldn't get a code.They say they think there are two pressure sensors on the 90 ELX,one is the MAP sensor and the other is a fuel sensor. Any one know and if so could they have knocked....when the alternator was fitted.
Also whilst I have been reading posts on the forum I have seen references to a Red Key,what is it and what is it for and should I have one? Thanks
Old 23-02-2008   #6
Quote Originally Posted by dodgemeg View Post
red key is to re program ur ecu for ur imobilser incase u loose ur blue key'
also, if they cant get a code, change ur garage' cause thats stupid.
the map map sensor, fuel sensor is in the ecu'
even if the garage did knock this... its wrapped in a pritty tough metal plate'
inecjtion lights can mean alot of stuff as simple as a air leak and they might be taken advantage of u.,
http://bebo.com/-chris-m < --- ****ty Punto!
Cellgm is offline Reply With Quote Quote
Old 28-02-2008   #7
Just to update and thank everyone. It was the MAP sensor, a small piece of plastic that a pressure pipe fits onto had broken off. £95 + £30 for the diagnostic test,much better than £300+. She's runnung like a dream now.
PS. Also the code problem occured because the Cabriolet come under the 1200cc thing and because mine is 1600cc it wasn't showing.
The key code light and fuel injector light stays on nena_k Lets Talk FIAT 3 28-04-2010 17:28
(T) fuel injection warning light and stalling crow1 Punto (Mk1) 12 27-10-2009 12:14
(G) Warning light and boot light Boanerges Panda 48 23-05-2006 16:25
(T) Fuel Injector warning & erratic revving Bosco Punto (Mk2/2b) 1 30-04-2004 01:19
