Old 11-02-2007   #1
GTI Till I die
Randomman's Avatar
Randomman has donated!
Free Lancer Champion
tinting rear lights
Hi all,
Any advice on tinting the mk2 rear lights? I've tried a search but there are a few too many results to say the least! Anyone tried it, or know someone that has?
I know about the actual tinting as I've done it before, but anything regarding taking the lights apart or photos of how they look done would be greatly recieved.
Team TD 124.9bhp & 209.1 ft/lbs torque
Quote Quote:
if you could get a jtd up to 7k you'd be doing 223mph
Cereal!? Ha! I eat cereal for breakfast!
Randomman is offline Reply With Quote Quote
Old 11-02-2007   #2
dave's Avatar
Trader Rating: 10
dave has donated!
Re: tinting rear lights
you dont take the lights apart, you just take them off, clean with thinners, then spray with light coats of savage tint spray.
after a few days you can buff um up with a bit of polish
THIS IS WHY TORIES CANT CLAIM HINDSIGHT! https://www.youtube.com/watch?v=bQDPQ8bz7cU
Old 11-02-2007   #3
they way i did mine was to tape off the lights, use scotchbrite pads to key the plastic and then mix a bit of black paint into some lacquer, covered the lights until they were as dark as i wanted them. The finish was fairly matt so i covered them in a few more coats of clear lacquer.
Hope this helps
Andy
PuntoAndy is offline Reply With Quote Quote
Old 13-02-2007   #4
do you tint the inside or out side the lights, i have a mk1 punto and want my lights black as my car is black. what is best, spray it or paint it or just buy tinted ones
luigipunto is offline Reply With Quote Quote
Old 13-02-2007   #5
Outside natrually.
Use the Savage tint spray as suggested above, magical stuff easily applied and looks top notch.
Use this on my Black punto and made my lights look bang on. I didn't bother removing the lights just masked them off and applied.
Black Punto MK2 5 Door
Abarth Kit, Badboy bonnet, Tail lights & Windows tinted, 17" TSW Rocket 5's, De-badged/De-bumped, Cobra Sport Stainless Centre Section, Stainless Raggazon DTM Rear box, Colour Coded!
kayone is offline Reply With Quote Quote
Old 13-02-2007   #6
where can you get this spray from and how much and does it effect the insurance?
Old 13-02-2007   #7
dave's Avatar
Trader Rating: 10
dave has donated!
you get it from ebay, it will depend on the insurance company and how they treat modders.
this masking up sounds daft, it must take longer to mask them off than to remove them, its only 2 nuts a side to remove them
Old 13-02-2007   #8
Supercharger whine :)
Si - Punto's Avatar
Si - Punto has donated!
You would have to be pretty lazy to decide that removing 4 bolts is too much effort in order to spray the lights.
I removed mine from the car and then masked them up before I sprayed them.
Mine came out quite matt and slightly rough because I rushed them Just take your time and do it right and they will look good
Mine are looking slightly better now that I have given them a going over with some rubbing compound
I need to give them another polish to get them perfect but to be honest I've kind of lost interest in the Punto since I bought the Bravo
Aero kitted R53 Cooper S - Electric Blue/White Roof
Gone but never forgotten
'54 Steel Grey Punto Active 1.2 - '99 Nero Black Bravo HGT 20v - '98 Broom Yellow Punto GT3 1.4T - '07 Crossover Black Grande Punto Sporting 1.9 M-Jet
Si - Punto is offline Reply With Quote Quote
Old 15-02-2007   #9
Well the not sure about the 3 Door, but on the 5 door it;s a pain in the arse to reach the top ones, and the tool isn't really long enough to properly reach to give you enough grip to easily remove the nuts.
Therefore masking which took me all of 5 mins with thick masking tape, was the easier option, and a plus was they were upright and easily sprayed rather than having to hang them up, as when i originally took them off and sprayed them flat on the floor it became lumpy and puddles up slightl
Old 15-02-2007   #10
just can't get enough
toad101's Avatar
toad101 has donated!
randoman: if the weathers dry this weekend i'll be doing mine and i'll post some pics mines a met gold mk2 same as yours
toad101 is offline Reply With Quote Quote
Old 16-02-2007   #11
Geek of the Week
smokeyjoe03's Avatar
Trader Rating: 1
smokeyjoe03 has donated!
Aniki Pingpong Champion, Rat Zapper Champion, TIE Fighter Shooter Champion
Quote Originally Posted by kayone View Post
The tool goes over the nut and has two holes (one either side) so slide a screwdriver through the holes and use this to turn it.
When I 1st got my punto (5 dr) the very 1st thing i did was replace a brake light bulb and it took longer to find a bulb in the shed than to remove the lights. Literally 1 min per light max.
smokeyjoe03 is offline Reply With Quote Quote
Old 16-02-2007   #12
Quote Originally Posted by smokeyjoe03 View Post
I would have used a screw driver if the hole in which you use the tool was wide enough.
Old 16-02-2007   #13
toad101's Avatar
the one supplied with the car fits mine
Old 17-02-2007   #14
Quote Originally Posted by toad101 View Post
The hole in which the screw fixings sit, not thew hole on the tool.
Old 18-02-2007   #15
toad101's Avatar
here's a photo of mine so far, i put four coats on the lights and one on the reflector, i might give it another coat or two
(T) Marea - missing rear right lights dansuni Marea 4 04-12-2006 08:14
(T) rear fog lights are on all the time rike Bravo / Brava 4 01-11-2006 12:26
(G) Rear Lights question MiniG Stilo 3 01-10-2005 15:05
(S) Tinting rear lights AIJ29 Cinquecento / Seicento 19 01-08-2005 13:00
(S) Rear lights Neofolis Stilo 26 12-10-2004 23:43
