Had similar problem, had to remove motor and strip down ,found the spindal that connects to wiper arm was seizing ,cleaned and new grease no problem since
I had a similar problem - the wiper would not stop! The problem then started happening with the front wipers as well. It turned out to be the switch on the steering column that was faulty - the whole darn thing needed to be replaced.
