Now this is assuming I've read my Haynes Manual correctly
It appears I can remove the caliper and position out of the way of the disc by removing the two 17mm bolts behind the disc instead of taking the caliper apart.
Despite trying some WD40 24 hours earlier on the bolt, the bottom one just won't budge.
Is this a common problem and is there any easy solution? I'm trying to avoid having to take this into a garage to get access on a ramp
