Old 18-12-2003   #1
Brake Light
Might sound a bit dumb but could anyone say how to get to the rear ligh cluster to change a brake light on a Fiat Punto 03 model 5Dr.
Thanks.
Bill.
bill miller
nippsnow is offline Reply With Quote Quote
Old 19-12-2003   #2
I'm not sure about the new Punto but on my Mk 1 the whole rear light cluster comes away by removing a couple of bolts on the boot pillars. The new Punto still has high lighting of course so I would guess that bolt is still there, probably hiding behind a flap and/or some boot upholstery. The Mk 1 comes with a plastic tool in it's spare wheel tool kit which enables you to undo said bolt (mind you it's so weak I used a socket set to do it) but I honestly haven;t got a clue if that's still how it's done. That bolt's got to be there somewhere though I'm sure, because they do still have high pillar lighting.
Assuming you get there, once the cluster is loose be careful not to drop it! Unplug the wiring connectors and take the cluster inside or somewhere light to change the bulb. I think I'm right in saying it's the lowest light on the latest Puntos? It should just be a standard twist out, twist new one in jobbie. Then replace the whole cluster and tighten her up. Remember, I'm just assuming that the same basic principal has remained true for the latest Punto's, but it does seem likely.
Also, this should be in your handbook I'd have thought.
Spirito di Punto
pritch is offline Reply With Quote Quote
Old 19-12-2003   #3
Thanks Pritch for taking the time to reply.
It is in the handbook but to be honest it is not very helpful.
I will be able to sort it out it is just that I can't see a way of removing the felt covering to get to it, but there must be a way, I will take another look.
Thanks again.
Bill.
bill miller
(T) Brake bulb warning light anthemmaster Bravo / Brava 10 24-03-2004 04:44
(T) 3 Brake Lines & a ABS Light Q TOY Bravo / Brava 1 13-03-2004 03:43
(G) Brake light problem - help! Surrey Sporting Panda (Classic) 8 01-07-2003 03:23
