Old 09-12-2005   #1
Rear Tail Lights Fault
Hi.........My 2000 Mk2 punto has recently been experiencing some problems with its rear tail lights. Initially the amber warning light on the dash board came up to indicate i need new bulbs as neither light was working. However since replacing the bulbs this warning light has still been flashing up, and i have discovered that the drivers side tail light needs to be knocked for it to come on initially. Once this has been done its fine until the cars been off for about an hour, and then when the lights are turned on this has to be done again. Can anyone shed any light on this problem?
Duxy
Duxy is offline Reply With Quote Quote
Old 09-12-2005   #2
Cool Re: Rear Tail Lights Fault
It's a current sensing circuit, that checks the bulbs are working in spec. If your replacement bulbs are giving you troubles, I'd check that they're of the correct wattage and voltage for the car. It might be that the resistance is too high and so it thinks they're blown again.
I wish all cars had this as at least you know to check them.
Ex Teseo Blue Punto 2000W Mk2 ELX 8v Owner. 4.5 years and 60k miles worth of Punto joy. If you see W871TBL, let me know...
Gav is offline Reply With Quote Quote
Old 09-12-2005   #3
I've got the same 'problem' sometimes when I press my brake pedal the light on the dash comes on I'd say once a day in a 50-100 mile drive. All my lights are working though
Someone at FIAT said it may be a 'bad earth' whatever that means
HardBoiledEgg is offline Reply With Quote Quote
Old 11-12-2005   #4
I had the same problem; all I did was to clean the contacts. As was previously said "It's a current sensing circuit" obviously if the contact are dirty it has an effect on this. Tapping the contact can have an effect some times & heat from the bulb can help stop this in subsequent times but when things cool down it needs tapping again...
Sounds plausible anyway!!
pmbertron is offline Reply With Quote Quote
(T) rear fog lights are on all the time rike Bravo / Brava 4 01-11-2006 13:26
(G) Fog lights + tail lights Drinu Uno 5 01-09-2005 21:43
(S) Tinting rear lights AIJ29 Cinquecento / Seicento 19 01-08-2005 14:00
(S) Sei Rear Lights MintySport Cinquecento / Seicento 21 21-05-2005 16:43
(S) Rear lights Neofolis Stilo 26 13-10-2004 00:43
