Thread Tools
Old 4 Weeks Ago   #1
Bypassing Transponder in Fiat Punto 1.2 8v
Hello to all again, this car just seems to be the biggest problem maker in the world but oh well. Does anyone know how to bypass a key code error or even the transponder in the key all together, for example just having a start stop button in the car. This is because I can't seem to find out why the car keep coming up with a key code error I have had the key checked and they said it was fine. Any thoughts or ideas would be be very much appreciated
Lockness is offline Reply With Quote Quote
Old 4 Weeks Ago   #2
You can only bypass it by using the bypass code available at fiat,at a cost,and press the code in using the throttle pedal. Ok the bypass system to check,but pain in the butt to do this daily,as far as Iím aware.
multipete is offline Reply With Quote Quote
Old 4 Weeks Ago   #3
Re: Bypassing Transponder in Fiat Punto 1.2 8v
Check connectors and fit a new aireal is about as much as you can do,or find a virgin ECU
Old 4 Weeks Ago   #4
Quote Originally Posted by multipete View Post
Yeah I changed areial about a couple weeks ago and the problem seemed to have stopped but after I changed starter motor the issue has come back
Old 4 Weeks Ago   #5
I take it the padlock sign comes on and it turns over but wonít start. Changing starter wonít alter any thing unless you disturbed an earth or live wire required for key code or engine ecu unit!
Old 4 Weeks Ago   #6
Yeah that's the problem and no I don't thing I have did it all made sure most connections were sound, and it ran perfectly fine yesturday. Just hasn't wanted to turn on today
Old 4 Weeks Ago   #7
Have you tried taking the transponder out of the key and taping it to the steering column near the aerial wire? Gotta be careful slicing the key up though to get the transponder out.
nitramtpr is offline Reply With Quote Quote
Old 4 Weeks Ago   #8
Quote Originally Posted by nitramtpr View Post
Nope I haven't tried that, but bit cautious to do that since planning on selling the car
Old 4 Weeks Ago   #9
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Bypassing thr immboliser will redner it even more vunerable to thieves.... and most likely also invalidate your insurance
Get the codes read in the ecu module to find out why its coming on
It may forwell be a canbus error which sometimes shows us a key code error when it actually isnt
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Thread Tools
(T) Bypassing the AC Compressor lukekazi Punto (Mk2/2b) 12 08-05-2018 01:53
(T) transponder fault fiat punto colinp123 Punto (Mk2/2b) 2 25-05-2015 21:58
(T) Transponder for punto Nemean Punto (Mk2/2b) 9 13-01-2011 14:19
(G) bypassing immobiliser hemz Punto (Mk2/2b) 1 22-02-2008 14:01
