Hi guys,
Always had the two airbag lights present on the dash since I got the car a few months ago. I'll be honest, I procrastinated on it a bit because I knew from a friend that the Puntos do have their weird airbag faults.
Just had a look at the codes and I got three through:
14 - Passenger airbag exclusion switch - Interference detected / faulty signal - Intermittent - 14
14 - Passenger airbag exclusion switch - Open circuit - Intermittent - 14
02 - Control unit power supply - Value too low - Intermittent - 94
The entry I'm most concerned about is for the control unit. When I first got the car it's battery wasn't great (winter snow ended up killing it) and I replaced it about a month into owning it. Is it possible the bad battery could've been messing with the control unit? Or am I looking at possibly getting a new control unit (little bit pricey)?
Are there any inspections/tests I can do to see if the control unit is all good?
