dubsential
- May 31, 2016
- 91
- 33
Hi I have fitted a facet pump and removed the pump in the tank also extending the pipe that goes in the top of the pump so it is receiving fuel from bottom of tank...
Having disconnected fuel supply from filter to engine and ran pump with 12v source fuel is moving through
But turning over engine won't start pump is a facet 4.0-6.0 psi the newer posi flow...
I understand the car has the mechanical pump
Am I giving it to much pressure the idea Was to splice it into the cars wiring for standard pump but after finding correct wiring no response from pump.
As mentioned firing it with a 12v source car just turns over, I was going to put it on ignition relay as splicing original wiring failed..
Thanks in advance if you know.
And the idea was to run thinned veg oil.
