dubsential
- May 31, 2016
- 91
- 33
I'm going to have to keep her topped with plenty of chippy oil lol from now on for hills... I. Do thin it down with petrol believe it or not don't need alot and it goes like stink and actually
Does with all that fat burning lol.
I did it in an old golf ahu engine the bosch in that had some clout so does this but it loves it's lift pump..
Someone mentioned that these in tank pumps often need replacing, I'm thinking the mesh on the bottom is clogged in most cases but bushes do wear out after all...
I have no mesh now but really I'm not filling it up with sand so I think it will help with the veg suction ability..
Il just keep a spare pump in the car and get a new bucket from scrappy at some point.
Basically think of it as in tank pump fitted back in as was minus bottom of bucket and that gauze on bottom of pump, which I know is to protect pump but veg is slightly thicker and reacts a bit by cleaning debris from diesel over the years and clogging it..
Next just behind the tank is the facet with a little filter attached....
This is what I'm wanting to put to switched live.
It all works fine and is basically three pumps in series, I believe it will help push the slightly thicker fuel through as mentioned the one in tank is lift pump this is pusher ie facet pump...
I'm just wondering on the ampage rating of that orange switched ignition wire and if it will take the posiflow facet pro243-k
I shall do some investigating on Mr Google but if anyone thinks they know the answer and if I need to put it on a switched relay or I can fudge it in let me know..
Cheers again so glad it starts yay
