hi,
It is a punto mk2b 1.2 8V.
Have this problem that happened twice until now, when starting the engine,
it's shaking and juddering.
Check engine light came on.
Obviously one of the cylinders is not working.
Strangly the Check engine light turned off after a day.
I connected the ECU to Multiecuscan program, and got these fault codes:
P0303 - Cylinder 3 ignition failures
P0300 - Ignition failures (generic)
P0351 - Coil 1
Is the coil gone bad?
Is Coil 1 is for cylinders 2 & 3 ?
Is it the one i marked in the picutre, or the other one which closer
to the windshield?
Is it safe to drive the car when the fault doesn't appear? can it damage something?
I have another punto which had similiar fault ( P0352),
and it turned up to be the ECU causing the problem.
Hopefully this is not the case here.
What do you think?
Thank you.
P0351 - Coil 1
to the windshield?
What do you think?
Thank you.
