Hi guys, I am new here. My other half's got this punto I am stuck with it.
I try to be short on a long story. Since we bought the car I knew she is missing a little bit, than I tought I'll sort her out after (she had new MOT). Started with common things : Plugs (bosch 0.9mm gap) leads, coils,ECU. The ECU was from ebay but I still sent the original to ecutest but it came back with no faults.Than I moved on vacuum leaks... replaced intake manifold,and trottle body gasket. Didn't fix it. Double checked timing, but it is right. Had injectors out ultrasonic cleaned them and "tested" they do open and spray, also added injector cleaner to the fuel. It' driving me nuts now, could you please advise something what else it could be? I would really appreciate it. My only concern is that the spark seems to be weak to me, when I jump it to the earth like 10mm it is really thin and it turns orange instead of blue. In my experience you should get a strong blue arc within 10-15mm. Does it make sence? I might be wrong... As the MOT coming up soon I took her for preMOT but she failed staight away on emission.
Anyway thank you for any suggestion.
Kind Regards Attila.
