AdamMaguire
Hey folks.
I've been having a bit of an issue with the gearbox/clutch on my Punto and was wondering if people might have some advice...
It essentially started with some infrequent grinding noises when in 1st/2nd gear...
Then, on one occasion a few weeks ago it wouldn't go into gear at all - so I put it to neutral, and took my foot off the clutch for a few seconds (while rolling down the road!) and it was fine again.
Since then I've still had the odd grinding noise, along with the odd issue with reverse.
In one case it got stuck in reverse - which was "solved" by letting out the clutch until I heard a bit of a 'dunf' noise and the gear engaged normally.
More commonly, though, it won't go into reverse at all (the stick moves fully to the right - it just won't slot in to gear). When this has happened I usually inch forward and then try again, as if something needs to move slightly to line up correctly.
Today, though, it just wouldn't go in... I left it for a while, tried again and eventually go it to pop in as if nothing was wrong.
So with all that in mind, can anyone suggest what might be the issue? More importantly, is there a simple fix I could do myself that might solve it - or at least buy me a bit of time?
I've spent a fair whack on this car to date and don't think I could muster another few hundred quid - So essentially it's a case of a simple patch job or Punto heaven!
Thanks.
Thanks.
