Old 24-06-2014   #16
Re: Camshaft position sensor error P0340 + melted airbox!
Quote Originally Posted by a1ant View Post
The lights on the dash are actually SMD (led) and cannot easily be removed, and I've never personally known one "go" of its own accord. A common trick though is to put some black tape over the SMD on the board.
The dash does a self test on startup, and if a SMD was faulty, it would say "LED fail" in the display where your mileage is.
To me, it says that whoever sold you this car couldn't solve the problem your having and simply taped over the SMD for the EML. Tut tut.
Alan
The weapon of choice for concealment was black permanent marker.
Used nail varnish and a flathead screw driver to get it off.
Disappointing...
Bumblebee1 is offline Reply With Quote Quote
Old 24-06-2014   #17
It gets better. Now I can hear a high pitch ringing noise when above 35-40mph.
First Fiat and probably the last. Anybody want to buy it?
Old 24-06-2014   #18
Burkina Faso (Upper Volta)
Quote Originally Posted by Bumblebee1 View Post
hi
buy a vw polo
they give no problems at all
then again neighbour put heres in for repair yesterday for mot
600 for mot, new rim and new cat apparently
cars eh
Likes atom0007 liked this post
s and b is offline Reply With Quote Quote
Old 24-06-2014   #19
Busy rebuilding pand'a
oldhammer's Avatar
oldhammer has donated!
(Now I can hear a high pitch ringing noise when above 35-40mph.)
from what area of car?
why get rid?
just have it sorted.. it will work out cheaper than buying another car.
my punto was a p.i.t.a to start with but now everythings sorted on it its prooved to be a very reliable car,
faults with cars are nowadays fault of the last owner scrimping and scraping
not the fault of the car,
good and bad in all makes.
Likes homeward liked this post
if some one has helped you here click the thanks button it costs nothing,
oldhammer is offline Reply With Quote Quote
Old 06-07-2014   #20
OK been away for a few days and I'm back now. The high pitch ringing sounded like from the front of the car / engine bay area. I don't hear it all the time. Another thing I noticed was that the oil level was practically empty, strange since it had an oil change a not too long ago. I looked underneath the car and there's a slow oil leak that's leaking on top of the gearbox which is why I didn't notice it on the floor after it being parked. I topped it up with but the ringing continued. I haven't heard it for a couple days now.
I still have the camshaft position sensor error and pre cat lambda error so still need to check the timing.
(T) Camshaft position sensor, MAF & Engine speed sensor Cathalo Doblo 2 15-06-2012 19:45
(T) No signal from Camshaft Sensor P0340 Fault Code MaverickJ Ulysse 2 31-01-2012 00:04
(T) Camshaft Position sensor Lovatt Punto (Mk2/2b) 8 11-03-2011 16:27
(T) camshaft position sensor sporting_adz Punto (Mk2/2b) 13 10-11-2009 21:57
(T) Camshaft Position Sensor ? SwissTony Stilo 13 07-07-2007 21:26
