Recently I discovered that the engine in my car isn't the original expecting a 188A4.000 engine code I found a 176B4.000 engine code, I checked the vin number which is ZFA188000 and the number below the engine code on the block doesn't match the log book. So I looked around and found the engine would of been from the punto 60 range and a spi set up. I've been told the cylinder head and manifolds are different. However I have the plastic black intake manifold with the 4 injectors. My problem is that I recently purchased a p75 fully ported and polished mpi cylinder head (with 866 cam) and am now concerned that it may not fit/work properly and the same for other parts I've brought ready for the engine overhaul.
Has anyone seen or heard of this before?
