hi all,
got 1.2 8v mk2 punto
i keep getting the same problem over and over again...PO115 engine coolant temperature circuit malfunction
i have changed the coolant sensor 3 times twice with euro parts sensor once with dealer part...it seems to work for a while but happens again couple weeks later but tbh i dont think its the sensor think it just on an off when it wants
the coolant temperature dial in the car stops working temperature showing zero...overheat (red light) comes on...fan stays constantly on until engine is turned off and left for 5mins...both coolant hoses are stone cold because fans been on so long...engine management light comes on...then on its own will just start working again :/
whats up...im guessing its the wiring now...do you think if i cut off the old connector plug and solder a new one on it will cure the problem?
cheers
brin
cheers
brin
