My Mk II Punto won't start, the oil and the 'Code' labeled immobilizer lights on the dashboard are on when trying to start engine (immobilizer light NOT flashing), the starter motor is running. At the same time the relay switch on position T09 in the fusebox under bonnet is giving a noisy fast clacking sound when the ignition is on. Swapping it with another red 9K labeled relay the same was happening, the new relay at T09 was clacking.
Anyone has any idea what's wrong?
Is the immobilizer at fault? I don't have the code, so couldn't try with it.
Does anyone know, what's the relay switch at T09 for?
Thanks,
Vilmos
Thanks,
Vilmos
