- Jan 18, 2006
- 1,203
- 367
Hello all!
Right a house mates GF has a Y-Reg 1.2 8V MK2 Punto.
It has a misfire from cold and most notable at 1500rpm, pulling away it tried to stall but with more throttle load it then pulls normally.
Has anyone had a similar problem?
I dont have any OBD2 equipment to interrogate the ECU but I did check each coil by removing the primary circuit connector on a coil pack and then cranking, both times each coil pack ran the relevant cylinders.
