Hi i have a fiat punto mk2 8V (2001), i was justwandering if anyone can tell me where the OBD port is on my car.
Ok, i have found it and plugged the diagostic machine in and there are no codes coming up, the reason i did this as my car seems to judder when pulling away for the first time after engine is started, i got told that the machine would tell me if any sensors we broken or dodgy.
It judders and recently it seems harder to put it into gear 1 & 2 but others are fine, can any let me know what causes this problem.
Try a loose or weak / failed engine mount, or more likely oil contamination on the clutch if its OK once you get past the first pull away of the day.
Your car is not OBD 2 compatible, this regulation was not enforced on petrol cars until 2002. Your machine wont help a lot
Ok thanks, would i just need to empty oil and replace it. And i will check the mounts.
Get used to it, its what 8vs do.
