- Joined
- Sep 20, 2020
- Messages
- 4
- Points
- 2
Hello guys,
Since 3 weeks my Fiat Punto '03 turned on the engine check light with red color.
I noticed a reduced acceleration and difficulties on reaching high speed with my Punto.
I did a check with Delphi diagnostics and it found out 3 OBD codes like below:
I sent it to 3 different mechanics and all of them gave different suggestions what could be the issue, one said the engine booster is dead, the other one said maybe there is any air leak through the tubes and the other one said maybe we need to change 1 sensor.
This is why I am not sure whether should I let them work on it or not.
I thought it would be better to ask here for any professional opinion about this issue from more experienced people about Fiat cars.
What would you suggest me to do to solve this issue? Would appreciate your opinion.
Thanks in advance.
Code:
[B]P0106 [/B]- Pressure sensor, inplausible value
[B]P0238 [/B]- Boost pressure sensor
[B]P0235 [/B]- Boost pressure sensor
Thanks in advance.
