hi people when i put my punto into neutral there is a weird rattle coming from engine bay but when i put my foot on the clutch the rattle goes away could this be the thrust bearing it is a 1996 1.1 55s if that helps.
Thanks.
Hi, they come with a clutch kit.. you maybe able to get them separately.. but if the cars clutch hasnt been changed.. seeming its a gearbox out job its worth doing the clutch at the same time.
Agreed, No point in doing just the bearing. Just do the clutch assembly. It might be damaged springs on the cover anyway, that might have been damaged by the release bearing.
