Old 16-07-2009   #1
You got Punto'ed
Momanatorz's Avatar
Momanatorz has donated!
Thumbs down Engine not starting after head gasket change
I believe ignition is working because i removed the 1st spark plug and starter motor turned faster. plug was also wet in petrol which means throttle body connections are ok when i re-fit everything.
tried re-doing the timing belt twice... no luck.
everything is connected, nothing left....
ideas? new leads/battery? the battery is pretty beat up by the looks of it ( i just bought the car )
i ran the starter motor quite a bit to circle the oil in the engine as i changed oil aswell during the gasket change
Momanatorz is offline Reply With Quote Quote
Old 16-07-2009   #2
sid23456 has donated!
Re: Engine not starting after head gasket change
could the head gasket be fitted the wrong way round?
sid23456 is offline Reply With Quote Quote
Old 16-07-2009   #3
You got Punto'ed
Momanatorz's Avatar
Lol, it's not really possible !
Old 16-07-2009   #4
You got Punto'ed
Momanatorz's Avatar
I think the engine is flooded though... gonna let it dry (no spark plugs)
and try late tomorrow evening
Old 17-07-2009   #5
Could be a couple of things. Its possible to be 180 degrees out with the timing. But its also worth checking that you put the alternator belt pulley back onto the crankshaft pulley properly. Between two of the three bolt holes, theres a tiny little locating peg which is so easy to miss. Very common. Best to check that thats lined up other wise the sensor pics up wrong readings. If its not this, try redoing the timing by rotating the crankshaft one turn. Dont worry about getting it wrong as its a non interference engine therefore wont damage the valves etc. It is possible to put the HG on the wrong way round, i did it once. Blocks the front oilway that delivers the oil to the cams, but the engine can be started regardless. Good luck
Thanks Momanatorz thanked for this post
Punto_2008 is offline Reply With Quote Quote
Old 17-07-2009   #6
You got Punto'ed
Momanatorz's Avatar
Quote Originally Posted by Punto_2008 View Post
Very useful info there mate! thanks alot
i am def sure the head gasket is right way around cos there's a sloped hole and i matched that with the head. and the thicker metal side of the rings face down. i think? i dont really remember that now lol.
it must be the crankshaft pulley peg thing, as i just whacked it on whereever the three bolts to hold it fitted. so if the sensor picks up wrong reading it wont start?
i don't quite understand how to line it up...
so on the actual crankshaft sprocket there's a lil thing stickin out?
Old 17-07-2009   #7
Trader Rating: 10
dave has donated!
Quote Originally Posted by Momanatorz View Post
it is possible, but it wont prevent starting
here is pic of the bit that does prevent starting,
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 17-07-2009   #8
You got Punto'ed
Momanatorz's Avatar
I meant it was not possible if you take your time and double check etc
Old 17-07-2009   #9
You got Punto'ed
Momanatorz's Avatar
Oh and thanks for the pic!!!!!!
Old 17-07-2009   #10
You got Punto'ed
Momanatorz's Avatar
Talking Re: Engine not starting after head gasket change
DUDE it f***ing works!!!!!!!!!!!!!!!!!!!!!!
Thanks alot for the crankshaft point !!!
I am so chuffed !!
the tensioner sounds worse than before though LOL.
ordered a new belt and tensioner the other day
sounds like the bearings are gonna explode !
but i'm so glad woo!!
first time experience with cars, and goes to show you can do it if you have the manual
Old 18-07-2009   #11
Nice one It's such an easily done thing on the first time. But now you know it's there, i bet you won't fall into that trap again! They should have really made the peg a bit bigger so you can actually notice it...
(G) starting after head gasket replacement levemircento Cinquecento / Seicento 10 03-03-2008 23:35
(T) ?how To Change Head Gasket? dr1v3r Uno 7 02-07-2007 17:08
(T) 1.4 head gasket change arc Bravo / Brava 2 29-01-2007 18:01
(T) head gasket change oldskoolmk1unoturbo Uno 0 07-11-2006 19:32
(T) post head gasket change/ starting tonym Cinquecento / Seicento 1 12-02-2005 22:30
