Thread Tools
Old 13-05-2008   #1
Engine Control System Failure and Power Steering Failure
Hi all,
After refuelling my car today (with the correct fuel I might add!) my car suddenly struggled to move. Two lights have appeared on my dash board, namely The Engine Control System Failure(EOBD) light and the Power Steering failure light.
Over the last couple of weeks I have had a few problems starting the car in the morning (not afternoons though).
After the above lights appeared on the dashboard, my speedometer showed no reading at all (i.e. zero) when I was moving at about 10mph! It struggled to go back down to zero again when I was in stationary traffic on my way home.
Any thoughts on what could be wrong?
Thanks.
oc99 is offline Reply With Quote Quote
Old 18-05-2008   #2
Re: Engine Control System Failure and Power Steering Failure
On reading the information in the thread link below, I presume that the above stuff is related to a common fault with the vehicle speed sensor. The symptoms described in the thread match the problems I had.
Am I correct in saying this is a common fault? How much is it likely to cost?
https://www.fiatforum.com/punto-guid...ng-column.html
Old 18-05-2008   #3
Forum Moderator
T14086's Avatar
T14086 has donated!
could well be mate, only way to tell is get it tested
Thread Tools
(T) Engine Control System Failure Stugadget Multipla 1 01-05-2008 23:11
(T) Engine Control System Failure lauren__07 Cinquecento / Seicento 7 24-02-2008 22:42
(T) engine control system failure m33ddy Stilo 3 03-09-2007 23:21
(T) engine control system failure m33ddy Stilo 0 02-09-2007 16:01
(G) Engine Control System Failure! ABARTHAK Stilo 7 01-05-2007 17:24
