im Axle Specialists
Old 18-01-2008   #1
glow plug light flashing
got a punto 1.9jtd and the glow plug light is flashing all the time and when you turn lights on the bulb light comes on but no bulbs are out all dash lights work aswell any suggestions thanks rob
utnut is offline Reply With Quote Quote
Old 18-01-2008   #2
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Re: glow plug light flashing
Hello mate, and WELCOME TO THE FORUM!
When you say the glow plug light is flashing "all the time" do you mean it flashes the whole time you are driving, or just for 10 seconds after you have turned the ignition on? If its just for 10 seconds after you have turned the ignition on, then it means there is a fault in your cold start system (glow plugs) most probably due to one or more glow plugs having died. Is the car still starting fine? or does it take a long time to start?
The bulb light will most probably be down to a bad earth in the lights. Hve you turned all the lights on and then put your hazards on to see if you are getting any interference between the indicators and rest of the lights. Also get someone to press the brake pedal with the headlights on to see if the break lights are effecting the other lights.
Hope that helps,
Alan
If you see a problem post, please click the report button
a1ant is offline Reply With Quote Quote
(G) Fiat Uno 1.7 Diesel Glow Plug Light rippedoff Uno 1 28-07-2020 10:19
(T) Diesel starting / glow plug issues Tipo Jack Tipo (Classic) 11 25-10-2011 22:21
(T) Oh no! What's wrong now?!?! Flashing Engine Light CatherineT Punto (Mk2/2b) 9 06-01-2008 19:01
(G) Amber Flashing light below airbag light on Punto stesand Punto (Mk2/2b) 2 28-11-2007 14:48
