hi all the wife has a 1242cc Mk1 1999 Punto 60SX which has been idling a bit lumpy I tried the test of unplugging the lambda sensor wire up at the bulkhead near the bonnet where the black square plastic cover is and then the engine idled lovely and smoothly then.
just a question I tried searching on here but not very successful but If i left that lambda cable disconnected would it ruin the cat on the exhaust and make the car use more fuel because as far as I can see the lambda sensor on the exhaust measures the amount of fuel going through the engine and adjusts the ECU for more or less petrol am I correct on that?
So has anyone drove around lots with it disconnected altogether without it wrecking the engine or cat converter?
If I were deciding to change the lambda sensor one day how easy do these unscrew from the exhaust? - bear in mind you are talking to a person who in the past has sheared bolts off engines before when they have been seized!! - what happens if the lambda sensor is a bugger to get out and snaps or cross threads? - does this happen often?
Cheers for any helpful advice,
Andy.
Andy.
