Still working on the MK2... getting there slowly but surely
Its a 1.2 8v. When i got the car i knew there were a few faults to sort... now ive come to the coolant. What happens is this... when i start the car, there is a huge pressure build up in the expansion tank. when i got the car it had very little coolant in it, but ive no idea how long it had been run like this tho.
So i drained and flushed the system, put new coolant in and bled it, then started the engine. within a couple of seconds, coolant was blasting out the filler cap, so i stopped the car and had a look on the forum read about possible thermostat and/or headgasket. I doubted the head gasket as when i first got the car it had an ICV fault which was revving the engine like mad - wouldn't have expected that with a blown HG. And once the ICV was sorted, it ran fine (bar coolant obviously.) So i drained the system into a bucket (no sign of oil in it) and replaced the thermostat. I also swaped the filler cap with a known good one from my other MK2. Refilled and bled, then started it up again. Exact same problem - coolant blasting out of the filler cap. I had disconnected coils so i could see if the symptoms were the same just cranking it over and they were.
Completely lost for ideas now... any suggestions before i start with the HG (only other possibility i can think of)?
