Old 13-10-2007   #1
CV Joint ?
Whenever I make a sharp left corner, I hear a scratching of metal sound, the sharper the turn, the louder the noise. Does this mean the CV joint needs replacing?
Please reply asap.
TCelica is offline Reply With Quote Quote
Old 13-10-2007   #2
Punto.Power has donated!
Re: CV Joint ?
Does it stop if you apply the breaks gently while turning? If so it could be coming from the pads or the discs, the CV Joints normally make a knocking noise when turning on full lock, you could turn the steering wheel on full lock at each side and look behind the wheels and see if the CV/Rubber Boot is burst or hanging off also leaking fluid.
This is what the CV Joint/Rubber Boot looks like..
Punto.Power is offline Reply With Quote Quote
Old 13-10-2007   #3
Re: CV Joint ?
Yeah, if its burst, you will see lots of grease all arrround that area
Shaunyboyuk is offline Reply With Quote Quote
(G) Suspension/ball Joint Question beejay182 Punto (Mk2/2b) 2 08-04-2007 18:36
(T) CV Joint MRT Doblo 5 22-03-2007 16:49
(G) CV Joint?????? lbarry Bravo / Brava 2 20-09-2006 11:25
(G) Tie Rod replacement (Steering) Alan.D Panda (Classic) 0 09-11-2005 21:12
(T) Ball Joint peaster2k Cinquecento / Seicento 2 13-02-2005 21:26
