Hi
I do not have a manual at the moment and I am trying to remove the off side outer cv gaiter and replace it with a new one. I cant see how the outer cv comes off the drive shaft. Does anyone know if there is a clip holding inside it on and if so where. i have cleaned it all up inside the joint and I cant see anything.
Its currently on axle stands with the strut disconnected and the clips holding the rubber gaiter removed.
Its a 2000 V plate 1.2 8 valve 5 speed, if that makes any difference.
Any suggestions are welcome.
