Old 01-07-2007   #1
Donate Donate Donate!!!!!
Jasperado has donated!
Punto JTD engine replacement
Looks like my head has been skimmed before leaving me with interference between valve and piston which is making my jtd run like a tractor. Thickest head gasket being used already! Can you just bolt in a different engine or do you have to replace the ecu etc?
If your reading this you should donate!!
Jasperado is offline Reply With Quote Quote
Old 01-07-2007   #2
Re: Punto JTD engine replacement
Quote Originally Posted by Jasperado View Post
If it's the same spec I don't see why not.
Why don't you just replace the head?
Decron is offline Reply With Quote Quote
Old 02-07-2007   #3
Probably will cost more than an engine.
Old 02-07-2007   #4
GTI Till I die
Randomman's Avatar
Randomman has donated!
Free Lancer Champion
Why would A JTD head be skimmed?
Normally if the head gasket lets water into the combustion chamber they... well... explode. (water doesnt compress all that well!)
Team TD 124.9bhp & 209.1 ft/lbs torque
Quote Quote:
if you could get a jtd up to 7k you'd be doing 223mph
Cereal!? Ha! I eat cereal for breakfast!
Randomman is offline Reply With Quote Quote
Old 02-07-2007   #5
I doubt this is the actual problem.
As per the puntomk2 forum, check compression to test if you have a broken valve, I think however it just needs some treatments through it if its running alittle rough.
Often people buy 5.99 for 5litre oils and then complain there is a problem with the engine...
Ex punto mk2 owner 1.2 8v with 94bhp.
Now owns a seicento sporting abarth bog standard and loving it!
Lowtechguy is offline Reply With Quote Quote
(T) engine swaps custard Cinquecento / Seicento 1 29-05-2016 09:11
(G) How many Puntos are there on the Forum? - The Thread FiatStiloJTD Punto (Mk2/2b) 543 06-06-2008 17:15
(T) engine swaps HP Cinquecento / Seicento 0 31-12-2004 00:17
