Has anyone replaced their reversing light bulb to a brighter one? I feel sometimes I cant see a damn thing when reversing... and that light is there to warn people as well as provide us with some lighting at night :/
Yes you'll need to solder or skotch lock them into place. I'd bin them and use the inline ones for ease and reversibility.
Rear ones on the Bravo being partly external had a lot of air circulating around them, fronts being in a headlight enclosure which has lots of heat from the bulbs anyway didn't cause me any concern, and didn't have issues over the 24 months I had the car.
For the front might be worth putting some insulation tape around the bulb holder to give it a more snug fit when putting it in place (I can't remember if I had to do this or not), but might be worth improvising![]()
Im guessing the 100w also contributes to a whiter light?
Not always the reason behind it, and don't forget 100watt bulbs are illegal to use on the road in the UK and are asking for costly problems later on with the car.
yeh i realised they are illegal... what problems can they present with the car being 100w?
Can cause the wiring to potentially burn out and cause a fire due to the additional loading, and if you're lucky it might only melt the chrome reflection off of the reflector resulting in light output getting worse and eventually having to change the headlamp units![]()
jesus christ lol... ill be changing them then
Use your brain
We already discussed this here : https://www.fiatforum.com/punto-evo/358445-xenon-filled-blue-tint-head-lights.html?p=3555575
sorry bud... my mind is all over the place
