FIAT Auto Specialist Team
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Punto EVO / 2012 Front indicator bulb replacement<!-- google_ad_section_end -->
Published by Andy Monty
16-06-2012
Difficulty Level: 2
User Rated:Unrated
Firstly if you dont have a short stubby pozzi screw driver or a driver with a flexi shaft you might find it easier to take the wheel off (no im not joking!)
if you can get a stubby driver stick the wheel on full lock to make access possible.....
now undo the 2 screws and remove the plastic panel....
now have a look inside the bumper you will see the back of the indicator...
Reach in and undo 1/4 turn or so anti clockwise *(you will feel the bulb holder release)*
then pull it out carefully towards you......
once you have hold of it remove the bulb press down slightly and turn anti clockwise and it will come out
refit the new bulb and put back together....
the bulb is an amber P21W (offset pins)
Thanks varesecrazy thanked for this post
Likes Balak, eddieyeo liked this post
Old 28-06-2014   #1
Switzerland
Re: Punto EVO / 2012 Front indicator bulb replacement
Thanks for explanations and pics, this is the official way.
But lying on the back next to the car, I put my arm from under the car and managed to change the bulb.
Be careful there are a lot of cutting part (sharp plastic), but it's so fast to change a bulb !
Punto 2012 Easy - 1.4 8V 77CV - Blue
Mkala is offline Reply With Quote Quote
Old 07-02-2018   #2
Israel
Cool
Prili is offline Reply With Quote Quote
Old 09-04-2018   #3
How do you replace the whole unit? Mine has split and most of it has snapped off.
Likes Balak liked this post
estone13 is offline Reply With Quote Quote
Comment
Search this Guide:
(T) Front indicator bulb... fiatol Scudo 2 08-10-2011 13:57
(G) No more Evo, just Punto from 2012 PandaLounge Punto Evo 10 06-09-2011 04:03
(T) Mk2b front indicator bulb smokeyjoe03 Punto (Mk2/2b) 3 06-07-2009 23:48
(T) Side Repeater Blows bulb in front Indicator Mighty_Kri Cinquecento / Seicento 7 19-06-2006 09:12
